How To - disable auto headlights Tahoe
whemic25
Worked great
These instructions are spot on, just did my modification in the driveway in just under 30 minutes. THANKS A LOT MAN
livingez_123
Sandy, OR
I did this last month, and it works perfect on my 01 Denali. No more HID's coming on when I unlock my doors at night.
Grimes
I wish my headlights lights would come on at night when I unlock my rig lol
I believe it is in the DIC settings, if you have that feature. I say that because 1, mine have never come on, and 2, I feel like I've seen it.
NGAneer
NWGA
Has anybody used a smaller resistor to trick the BCM into turning the lights on when it is truly dark? I'm thinking if a 1k or 1.5k ohm resistor tricks the truck into believing it's daylight all the time, could a 500 ohm (or something similar) make the truck think it was daylight until it was truly dark out? Thoughts?
NGAneer
NWGA
Kept my auto headlights with my HIDs. I wired in a voltage sensitive relay between the headlight switch and the passenger headlight. Since this actuates the control module for my HIDs (H13 bi-xenon) it triggers the HIDs only when there's enough voltage. I just turn the auto headlights off with the interior switch before cranking the truck in my garage during the day. Works great.
JonTiffany1
Owego, NY
If you depress the dome light kill switch twice it does the same thing. Just an option.
I press the dome override button 4-times and the auto headlights disable. However, after restarting the truck, the auto headlights resume as normal.
This is something I will definitely be doing! Thanks!!
Jon
Harpo123
