Help! I need somebody! Lol. Whining noise in video.
blatta1999
blatta1999
I changed rear diff fluid and had just a few shavings. Otherwise all looked good and the gears looked clean. I swapped out tie rods because they needed it anyways. Noise is still there. Shouldn’t I have seen issues with the rear fluid or metal if there was a problem? Next is swapping passenger wheel bearing.
what do you mean by shavings? like if you drilled on some metal type shavings?
blatta1999
blatta1999
I had read when you change the fluid you will have small flakes that attach to the magnet. And I had a very small amount of that.
mine was more of a paste so I was just curious if it was like metal corkscrews or something that wouldn't be good
blatta1999
blatta1999
No this was kind of a paste consistency stuck to the magnet with fine shavings similar to sharpening a pencil.
agmanw8n
