Heeellllppp!!!!
mr tahoe
Guys i need help my liftgate isnt working i keep changing the fuse and it keeps blowing everything else on the door is working... as soon as i press the button i burn the darn fuse any help or direction would be greatly appreciated
HiHoeSilver
Away!
Chicago
If you're truly blowing the fuse immediately every time, then you have a dead short somewhere. Either in the wire or the winding of the motor. If you can get to the motor, disconnect it and then try the button. If the fuse still blows, your short is in the wire. If not, give the motor a closer look. Locked up or bad winding.
mr tahoe
mr tahoe
Guys i disconnected the latch and it still blew the fuse how can i find the short
mr tahoe
mr tahoe
Its just the power lock my truck is an ls non powerd lift gate
Danny3737
Check the lift gate supports. If one or both are bad that is a lot of strain on the motor and could blow the fuse. I had the same thing happen on my Highlander
mr tahoe
mr tahoe
The long thing that has a button in the middle under the license plate the one that opens the whole gate and not just the glass / struts are working fine
jmart157
