blazzinbird
So my wife has 178k on her 08 Denali. I am planning on changing out the plugs and wires, and change the oil pan gasket, and trans fluid. What else would you do at this time?
Everything you listed is maintenance except the oil pan gasket, so I assume there is a leak there and it has been diagnosed correctly. Just because the oil finally drips off f the oil pan, if it is a leak, does not mean it is the oil pan gasket. It could be from up above and draining down to the oil pan. If you do all this work make sure you keep all parts receipts and document what was done and when and what mileage, so you can refer back to it if needed. Plus if you sell the rig, that list is worth money to you.
If it’s AWD, please know that to get the oil pan off your going to have to remove the control arm cross member, drop the front differential and lower the steering rack.
