Front end squeaking
jwrwjw
My 2013 GMC Yukon SLT has a popping, squeaking noise in the left front. It is worse when first driving it or backing out with the steering turned all the way out, but seems to go away after a few miles. I hear it also when I hit the brakes hard and the front end nose dives. Could this be coming from the rubber bushings in the front? I don't think it is the brakes or axle.
strutaeng
Dallas, Texas
Wheel hub? Jack the front end and do the tire "12 & 6 o'clock, then the 9 & 3 o'clock shake test" and the "spin test."
The control arm bushings you can listen with a helper jumping on that side of the vehicle to see if they squeak. Those usually squeak all the time and you hear them if you drive parallel to a wall or building with the windows down and go over a bump.
It may be a combination of things.
B-train
A dry ball joint will also make a similar noise. Add it to your list to check when it's jacked up to check what @strutaeng mentioned as well
Also, sometimes a bad strut will give a groaning sound too.
caprajohn
