Front differential bearing replacement
dkad260
2012 Yukon AWD
After rebuilding the rear diff, I would now like to address a possible LH output shaft bearing that might be worn. I don't think I will mess with the ring and pinion, this time, but I have noticable up and down movement where the CV shaft enters the case.
Does the front diff have tapered bearings on the output, or is that bearing just smaller roller in the spanner?
montanaboy65
