Feels like something slips, but only at part throttle
St. Louis
2012 Denali AWD
So lately I've been noticing from a stop with medium throttle it feels like the tires are slipping/spinning for a fraction of a second then they grab and I go. It doesn't do this at light throttle or heavy throttle. I know the tires aren't really slipping/spinning, but it's that feeling. Almost like a clutch slipping then grabbing on a manual transmission.
I don't have any codes and all drivetrain fluids have been changed within the past year. I've checked the drive shafts/U-joints and they seem fine with very little play. I was thinking maybe something like a bad motor or differential mount, but the symptoms don't seem the same.
Other than this slight annoyance when leaving a stoplight, everything else is fine, quiet, and smooth. I wonder if it's something internally with the trans?
wjburken
Eastern Iowa
2012 Denali AWD
Had similar symptoms on our ‘07 Denali. Replacing the transfer case helped and a new front differential took care of the rest. Also had the pinion bearing/seal on the rear differential replaced in the process.
gooffeyguy
St. Louis
How many miles were on it at the time? I just hit 120k, and everything underneath looks great, no leaks, seepage, or gunk anywhere
wjburken
Eastern Iowa
I was a little further down the line than you are. This all started above 200K. 120K seems a little soon for that type of stuff.
Might double check your front diff mount bushings closely.
Jimmyy
Minnesota
Try shifting into 1st when stopped and manually shift up. You could have a lazy pressure solenoid.
gooffeyguy
St. Louis
I'll check the front differential mount next time I get under it.
Engine mount is easier to check, I'll try to do that this week.
I'll try manual shifting it into 1st when stopped next time I drive it.
It's not that noticeable, and it's weird that it only does it (or it's only noticeable) with only part throttle (probably 30-50%) take offs. Not with normal, slowly easing into it take offs or hard, 50%+ throttle take offs.
What would signs of a bad converter be?
gooffeyguy
St. Louis
I messed with manual mode a bit on my way home from work today.
I think it may have something to do with the hill start assist
Like maybe I'm only noticing it when I'm on a slight incline, up or down.
Harpo123
