electro
Just looking for help pin pointing oil leak location.
RULING OUT: REAR MAIN SEAL, OIL PRESSURE SENSOR.
It's running down back of block and often will accumulate on sun shell and drip off that.
I want to rule out rear main seal and oil pressure sensor.
Where else could it be coming from. It looks like it's coming from a higher spot than lower.
By using an inspection mirror to look down behind the engine I can see possibly little bit of wet around near the pressure sensor. I just changed that though and I'd like to thing that's not it.
I park on neighbours nice raised aggregate driveway for the winter and I have to put a 2x2' mat down every night. Getting old.. I thought I fixed it with the pressure sensor buts it's not looking that way..
When I changed the transmission last year the leak appeared to be coming from a higher point than the rear main seal location.
I'm thinking valley cover, head gasket left side
Any spots to look for would be great!,,
Thanks guys..
Sent from my iPad using Tapatalk
Thanks guys..
