boomboom baker
Don't know if this is the right spot to ask this question but I have a 01 Tahoe I won't to do e fans what year model can I get the fans from and is it a hard swap
I know they started putting them in the 05 Suburbans and Tahoes. I also think they started putting them in the 03 Escalades. If you get the fans from a donor, try to get the fan harness with relays also going all the way to the pcm. You'll need a tuner to turn them on through the pcm. Hopefully if I'm wrong someone will jump in. I grabbed a set from an 05 Tahoe and bought the harness from ls1 fans, which I read in another thread might not be that great of an idea. I've yet to install my setup yet.Don't know if this is the right spot to ask this question but I have a 01 Tahoe I won't to do e fans what year model can I get the fans from and is it a hard swap
Do I need the radiator toI know they started putting them in the 05 Suburbans and Tahoes. I also think they started putting them in the 03 Escalades. If you get the fans from a donor, try to get the fan harness with relays also going all the way to the pcm. You'll need a tuner to turn them on through the pcm. Hopefully if I'm wrong someone will jump in. I grabbed a set from an 05 Tahoe and bought the harness from ls1 fans, which I read in another thread might not be that great of an idea. I've yet to install my setup yet.
Ok thanks my local pull a part is loaded with these truck going to get one this weekendNot sure. My 03 originally came with the 4.8, now has the 6.0. Radiator cracked. Parts store told me 4.8, 5.3 and 6.0 radiator sizes are all the same. Btw-i compared my old with the new and they we're the exact same size, width and length. I'd day just use your old judgement. But, measure yours and the donor's, just for piece of mind.
Lucky!Ok thanks my local pull a part is loaded with these truck going to get one this weekend
