Do I keep it?
Wrecker93
Hello everyone. I have been searching for a 2 door Tahoe since I was old enough to know what one was and over the weekend I bought what I believed to be a good one with 68,000 miles. However $2400 and a 5 hour round trip later I discovered a hole in the frame almost the size of my forearm that is both on the inside and outside. I work in a body shop and I should be able to fix it but the question now is do I keep it or get rid of it? Any help with this decision would be appreciated. Thanks.
95BlackTahoe
Edinburg, PA
Considering how clean it looks otherwise, and considering the fact that you say you can do it yourself, I'd just go ahead and do that. Two doors are getting harder to find all the time.
Shawn
PS, My friend loves his 95 pickup so much he just had a entire rear section of frame welded in. I myself may need a rear section from the bumper up about to where the tire would hang. And I will have it done too, cause the truck doesn't let me down any other way.
livingez_123
Sandy, OR
Find a new frame from the west coast. once you have cancer that bad it only keeps spreading, even if you cut and replace.
Gzes
the drifting 2dr
Wichita tx
I would come down to the south and get a good frame. There's a couple good 2drs here. Beats a Patched up rotted out frame..
Administrator
Swap onto a good frame
W
Wrecker93
That's what I was thinking would have to happen. How much would a frame probably cost? I've looked around but I can't find a good reference point.
_Dylan_
STAY FROSTY
dump it
get a fresh one from down south or out west
Gzes
the drifting 2dr
Wichita tx
No idea but labor to get everything off is gonna be the expensive part. Can give you a number to a local yard that has one and sells at good prices but kinda doubt you'd wanna come down to tx..
97WhiteYukon
if the body and interior are clean and what you want you could always find the opposite, one with a clean frame and junk body and interior for cheap and then put the 2 good parts together.
Dowsewashere
Dude thats unsafe. Your asking for an accident. Id either try and find a frame or part it out.
DetcJohnKimble
