coolant leak info/help
992dr
N.C.
I have a leak and am curious to know if anyone else has had the same leak.
If so, how was it replacing and did you need any specific tools to remove these lines?
It is coming from the "outlet hose" or "radiator urge tank outlet hose" not sure the exact name. Its that plastic Y that comes out of one port of the water pump.
Here's a couple of links to show the hose and fitting.
https://www.ebay.com/itm/2007-2014-...-Surge-Tank-Outlet-Hose-new-OEM-/261793278988
https://www.gmpartsdirect.com/oem-parts/gm-outlet-hose-15834772
Any help would be greatly appreciated.
Thanks
kbuskill
NE. FL.
I replaced mine but it's been a while ago... I don't remember needing any special tools and I bought it from one of the local parts stores.
If it is the one going up to the firewall and clips on just take some needle nose pliers and break the plastic part off, you'll be done in 5 minutes flat,
992dr
992dr
N.C.
Mine is leaking from the Y fitting by the water pump. But, I think its all one assembly.
Thanks for the info guys, much appreciated.
Laurents10
