Choppin' Blocks NEW 07+ Chevy Control Arms
Avs_Dom
Fresno, Ca
Hey guys check out our new products, this is for 07-10 Chevys, SUVs, etc. This is the same kit that Choppin' Block is using on that Tahoe they are building...
Anyway here are the details:
07+ Chevy Full size Front End Kit:This kit will lay your truck out with large wheels up to 26" rims. Reduces Front Negative Camber, Fixes Bump Steer Problems and Toe alignment. This is a weld on kit with self aligning locaters to assist with installation.
Includes:
Choppin' Block Upper and Lower Control Arms(Lower Shock mount and Lower Bag Mount already installed on Lower Arm.)
Choppin' Block 2" Drop Spindle with Tie-Rod Bump Steer Adjustment Built in.Including Adapter for Heim Tie Rod End Replacement.
Choppin' Block Upper Control Arm Relocater Kit, This kit includes Relocation of upper control arms to Reduce Negative camber issues and Bump steering issues. Also Includes Bag Mount Placement for Large Wheels.
Our Kit includes Choppin' Block Upper and Lower Control Arms, Choppin' Block patented 2" Drop Spindle w/ adjusted steering arm for Bump steer, 4-Upper Shock Brackets, 2-Heim Tie Rod Ends, 4-Misalignment Spacers, MOOG Ball joints for upper and lower control arms, 2-Turn Buckle Adapter for Tie Rod Ends,2-Front Shocks, All Hardware for shocks, For heim steering, Uses Stock GM Upper Control arm alignment Bolts.
One of these kits will run you $1595, This is one of the MOST complete kits on the market right now, The control arms will be powder coated silver.
waiteben84
