Center Console Squeak
mcimma
2011 Tahoe LT. The lid of my center console squeaks sometimes when my arm is resting on it. I've checked all screws and everything is tight. Anyone else ever had this problem??
Thanks
OR VietVet
Multnomah Falls
Military
Willamette Valley
Pull the armrest down and lean on it. LOL!
If is squeaking at the lid look for the rub spot or is it squeaking down lower?
JSMillar
My '11 used to do that. It's the leather and temperature related. Try some leather conditioner or stuff you would use on the dash.
Sent from my iPhone5S using Tapatalk
M
mcimma
Anything you recommend that worked for you???
RotaryMachineRx
Saskatoon, SK
This happens exactly the same for me, only when my elbow is resting on it.... I feel like it is the plastic latch itself squeaking...
JSMillar
Try armor all. I've routed my usb cable out at the squeaky point. It doesn't squeak anymore.
2012TahoeLTZ
I had the same issue.. I put some white lithium grease on a rag and rubbed it into the bottom side all around the bottom of the lid as well there are two rubber pads.. I also sprayed a little bit of that grease on the hinge on the back of the lid.. This took care of all squeking caused by the cold temperatures that we're having that contracting and expanding effect between cold and wArm.. Good luck!!
Sleeeper
