I have a 2011 Denali and it has the KNP (Cooling, auxiliary external transmission oil cooler). I think it might be standard on Denali trim level trucks. Anyhow we bought a new camper this spring and went out on our first trip this past weekend. I normally keep an eye on transmission temps while traveling with it. The trip was pretty short but the area we went was pretty hilly. Air temps were in the low to mid 70s and I was hitting 210F on the transmission. With our old camper we would rarely get that hot unless it was well into the 90s but this new camper is quite a bit bigger and heavier. In fact if we went any bigger we would have traded in the Denali and gone with a 3/4 ton truck. It is well within the towing rating and we are not exceeding axle limits or hitch limits which is really the limit not the 8100lbs that they claim in the brochures. I haven't gotten it to the CAT Scales yet but I would estimate that we are at about 6000-6250lbs.
Anyhow while I know 210 isn't really hitting a limit where I should pull over, it has be wondering about what it will be at when it is in the 90s? I was thinking about adding an aux transmission cooler but it already has one. Anyone else out there run into this? Should I pull the aux cooler and put a bigger one in or add a third cooler? Right now it first goes to the combination transmission/oil, then it goes to the Aux cooler and back to the transmission. I could probably fit in a second aux cooler somewhere.
Because of the towing I do the severe service interval and it gets new fluid every 50K. I also am running the synthetic fluid. Maybe it is nothing to worry about since these newer transmissions seem to run hotter than they did in the past and the synthetic won't break down as much at 220 compared to the older stuff.
