AC evaporator calls it quits at 32K miles?
ssgswole
I recently took my 21 Yukon in for regular service and the AC stopped blowing cold after a couple days of picking it up. Take it back in for service and they tell me that they need to replace the evaporator and recharge the system. They wanna charge me 3800 for everything. I've only got 32k miles on it and I drive it like a soccer mom. Should the evaporator be going out at 32k miles?
Micahsd
I'd say that's not normal. I'd see if they can do some customer appreciation thing though GM to avoid paying for the full cost.
I had a 2017 Acadia with the same issue in 2020...evaporator went out at 42k miles. Complained and they covered the labor and I only had to pay for parts. It was still a $1,400 bill but it was better than the full cost.
I take it GM doesn't do the 3yr 36k bumper to bumper coverage anymore?
right off the gm website for all 2016 and newer
NEW VEHICLE LIMITED WARRANTY
GMC vehicles registered in the U.S.A. are covered for 3 years/36,000 miles (whichever comes first). The complete vehicle is covered from bumper-to-bumper —including tires, towing to your nearest GMC dealer and cosmetic corrosion resulting from defects. Repairs will be made to correct any defect in materials or workmanship. In addition, rust-through corrosion will be covered for 6 years/100,000 miles (whichever comes first).
StephenPT
St. Helens, OR
Should be covered under warranty. If not, take it to an HVAC shop and ask them to look it over. Evaporator leaks are not easy to find, without dash removal. I highly doubt the dealer dug into it and found the evaporator leak point.
Your problem could also be a heater blend door actuator. Proper diagnosis is key and I would get a second opinion.
Welcome to the Forum from NH.
Pics of the truck, please.
WalleyeMikeIII
Sunny and Snowy Minnesota
Was this at the dealer, or an independen shop? As others have said, should still be within the 36k mile warranty; but depending on the date this particular vehicle was palced in service, you could be past 3 years.
ssgswole
ssgswole
My warranty expired in November of 23 and it doesn't sound like they will extend me a courtesy.
ssgswole
ssgswole
Dealer
Thekenstar
