olliec420
- Joined
- Apr 12, 2016
- Posts
- 167
- Reaction score
- 122
The 98 is doing great. Only issue (well besides the minor ignorable ones) is it has recently started squeaking on startup. See video. Anyone know what that is?
It is very rare but I have ran across where a seal will have a squeak noise till heat builds in it. I have found noises at the rear main seal and the harmonic balancer seal.my Wifes's 99 has the same problem, i have changed every pulley and the tensioner twice, and the alternator recently, and still have the squeak. It is annoying at idle but you can't hear it if your windows are up going down the road. It does go away once everything is warmed up. i am sure something will fail then i will really know what it is.
Or turn the radio up if the windows are down......but you can't hear it if your windows are up going down the road....
Have you confirmed you don't have a weeping water pump? That could be a culprit too, in my experience.The 98 is doing great. Only issue (well besides the minor ignorable ones) is it has recently started squeaking on startup. See video. Anyone know what that is?
