95 tahoe abs codes
mike101prf
I am having trouble finding out what abs codes mean, anyone have any links or information on codes 25, 26, 37. any help would be greatly appreiciated
BlueTahoe2001
Charlotte, NC
Do you have a reader? Or did someone check these codes for you? If you have a reader it should have came with a whole list of codes and what they mean.
M
mike101prf
a mechanic read it with a snap on reader, but he didnt have the list of the abs codes with him
i
BlueTahoe2001
Charlotte, NC
Maybe try looking it up on google? Or try calling around to different shops and see if they can help you. I have a list for OBDII but I think yours is OBDI...
96ProCompTahoe
IN
i have a book for the OBD1 reader. (the one that makes your SES light flash for the codes) if thats what your is i can go dig it out in the garage.
haks310
Got LEDs?
SoCal
You will find the OBD1 ECM codes online on google easily...the ABS codes are the ones that will be hard to find.
96ProCompTahoe
IN
my book only goes up to 94 so these may be right or completely wrong:
25: Left Front Wheel Speed Sensor Circuit Resistance is Incorrect
26: Left Front Wheel Sensor Voltage Output is Incorrect
37: Left Rear Wheel Speed Sensor Voltage Output is Incorrect
M
mike101prf
i wasnt able to find them online, but i work at a car dealership not a gm and luckly found a tech to find them in his all data stuff
it sounds like the 94 is the same as a 95
25-26 left front speed sensor
37 is kinda confusing all data said it was rear sensor but im thinking that its the left rear because of my tahoe having 4wal
kootamcgrabbin24
