6l80 Torque Converter for Towing Recommendations
scottbrew92
South AL
I have a 2015 Yukon Denali with the 6l80 and think I’m going to have to replace the torque converter. Any recommendations on what the best would be for frequent towing?
Marky Dissod
If you're thinking of an OE-type solution, there was a version of the 6L90E that GM had the guts to couple with the detuned LGH version of the DuraMax.
I suspect that torque converter, or one meant to withstand a supercharged CTS-V, for example, would be slightly superior to the one in a 6L80E attached to a lesser engine.
There are likely superior aftermarket solutions; at which point the cost-to-benefit ratio is the issue.
NickTransmissions
Sin City
The transmission bench
How heavy of a load will you be typically towing?
For most folks towing/hauling within or slightly beyond factory-engineered limits, something with a billet cover and .070" converter clutch at minimum. Circle D, Yank, Florida TC, TCI and many others to choose from. It may also be worth inquiring about a custom-low stall (as long as you don't have to stand on the brake pedal to keep it from moving at a stop) as well as exploring tuning options intended to optimize the powertrain control strategies for towing/hauling.
I believe the CTS-V converters stall at 2400 or so but could be wrong...If they are that high, wouldn't be ideal for towing as too much heat would build up and the lower stall gets heavier vehicles moving more efficiently.
Marky Dissod
... I believe the CTS-V converters stall at 2400RpM or so but could be wrong.
With a supercharged 6.2L in a 4000lb car, when you wiggle your ityybitty toe, the car moves a wee lil bit.
In a 'hoe / 'bubba hauling a family & towing 9000lb of stuff, yeah, that same converter might stall @ 2400RpM, which'd be ridiculous.
So which torque converter is used by the LGH / 6L90E vans?
NickTransmissions
Sin City
Regular JMBX. Stall is 1600-1800, I believe.
scottbrew92
scottbrew92
South AL
Thanks for the response, figured I’d try the flush at the dealer and surprisingly as bad as it was it totally worked…!!!
Thekenstar
