2wd lift
S
SYNASTR
installed the body kit today, relatively simple. ill post pics tomorrow. Got my 2 inch blocks but still waiting on other parts
S
SYNASTR
im hoping to get 6 plus inches out of it for cheap. . is it possible to take the 4 wheel drives parts from a 93 truck and bolt it up?
992dr
N.C.
Sounds like you're rollin. Lets see those pics.
Do they actually make a lift kit for a 2wd 2dr Tahoe? Whether it be inexpensive or very expensive? Just curious.
Thanks
S
SYNASTR
if this snow would hold off i would go put my blocks and spring spacers on. i got some 35 15.50 15 tires the other day so i need to get this thing up
96ProCompTahoe
IN
those are some wide tires you may have some rubbing on the frame at full turn. Also looking forward to pictures.
S
SYNASTR
ya they are on ten inch wheels. i got the bumper off dads truck which has already had alot of trimming to fit 35's on his truck. so hopefully i only have to cut at the rear of my fenders.
BigDaddy13440
Rome, NY
The blocks should work for the back, but I'd be wary of axle wrap. Personally, I'd find a rear end out if a newer van, with a lower axle ratio (4:11??), swap the spring perches and shock mounts.. the van axle is about 4" wider flange-to-flange. While you're at it, disassemble your leaf pack, slip 2-3 extra leaves in it and bolt it back up.
Put 4 leaves in my '90 Suburban when I swapped the axle with an 8-bolt out of a 1-ton van, gained almost 7" of lift, AND turned my 1/2 ton into a Ton Plus, carried 2500lbs of sheetrock w/o bottoming out.
Added 3 leaves to my current Tahoe, got 3", and a much more stable ride going thru corners, truck doesn't sway at all.
S
SYNASTR
i understand all that but what about the front? is it hard to swap to a solid axle?
S
SYNASTR
heres a pic with just the body lift
Richard A
