Blown trannies -no laughing matter at all (
lol!).
This is likely either TEHCM or valve body....
P0700 is a general transmission control module fault/failure code (in 6L transmissions, the TCM is referred to as the transmission electronic hydraulic control model or TEHCM for short) while P0796 and P02723 are solenoid performance codes (stuck on/off) but can indicate problems with the valve body as well as the TEHCM. P0796 refers to clutch pressure control solenoid #3 is stuck in the 'off' position while P2723 is telling you that clutch pressure control solenoid #5 is stuck off. Both of these solenoids are 'on' in first, second and third gear while CPC #3 comes off in fourth gear (CPC#5 is on in gears 1-4). So if CPC# 3 and 5 are stuck off, you'll have no forward movement.
P0796 can also indicate a sticking/stuck CBR1/4-5-6 regulator valve (upper valve body) while P2723 can indicate a stuck 1-2-3-4 clutch regulator valve (if this valve is stuck in the 'off' position, you won't move forward).
Next steps
Drop the control body complex from the transmission and separate the TECHM from the valve body. Take a multi-meter and start ohm'ing out all of your solenoids (see page one of
my 6L80 transmission info thread for instructions on how to do this). Then test your pressure switches (same thread for reference). Take note of the part number on the TEHCM that begins with '242' as it's critically important that, if you end up having to replace the TEHCM, you get one with the
same part number (or ensure the remanufactured TEHCM is programmed with the same operating system installed onto your vehicle's ECM).
If the TEHCM passes all tests, move to the valve body and separate the two halves by withdrawing the remaining bolts from the TEHCM side and all 12 7mm bolts from the speed sensor/harness side and begin stroking the valves in both halves with a small flat blade screw driver to see if any are stuck. If no stuck valves (or dragging valves) are noted, then the cause is likely a cracked 1-2-3-4 piston inside the 3-5-R drum inside the case and if so, time for a rebuild (may also be torque converter as these converters commonly fail for a variety of reasons).
Side Note for All
Checking the fluid at the dipstick actually tells you very little about what's going on inside the transmission (other than the level itself and checked while vehicle is at op temp), unless you drop the pan or it's absolutely filthy, by which point you won't need to check the dipstick to know the transmission is smoked.
Quote this post or mention me (
@NickTransmissions ) if you reply back to this thread with any questions for me so that I know you have responded. Otherwise I don't get alerts if you simply respond w/a new post without doing one or the other.
