2016 yukon xl denali 4inch lift 4wd
cbraga
Yeah, I’ve always had my trucks nose high. Even my wife likes them like that now. Lol. Only running a 1” or 1.5” I can get but without moving the rear shock down. If I go with a 2” I’ll have to add the rest of the rear kit. I’ll have to make the call after swapping the 1” for the 1.5” in front. I was disappointed to find out my hypertech speedometer calibrater wouldn’t work with the adaptive cruise control. Quick call to then and they said there is a second option for it with an in line system. Ordered that, will report back.
cbraga
Surprised the Fabtech front spacer is so small. These were my tire choices. Stock, 285/50, and 285/55 r22. Nitto terra grapplers
You can see them against the 35” tires on my 2500
3C2C396C-DD55-430D-811F-C357F5ED66B4.jpeg C39831B3-7DD8-4FA0-94AC-69D0E2B97295.jpeg 9BC57574-953F-4DE8-8E70-A88AB49A4315.jpeg 09A5A934-9082-43CC-B621-191F7BDC108C.jpeg
InTruckDesign
SW CT,
Cbraga, truck looks nasty!!!
Any pics of the front lower spacer you added and also what size wheel spacers did you go with? I am currently trying to figure out my wheel tire combo, the Fuel wheel/tires have been great except for the tires going out of round and wearing all weird(rotated every 3-5k) Thinking on painting my stock 22's and putting some 285/55's on them. Oh and you have any fender height measurements?
TIA
cbraga
TIA
I used Bora 1.5” wheel spacers all the way around. The front is right st 40” with the 1” spacer added to Fabtech kit. The 285/50 measure out to 33.5” tall.
676ABB6D-DBA2-4E10-B8B2-F6B9198E6AB5.jpeg A5B14C4D-B97F-48C9-A8FE-E882B8F93654.jpeg F2267313-10F0-4C3A-9C79-554A7F73E867.jpeg
01Konvict
Boats n Hoes
Raleigh/SML
@cbraga Denali looks great!! Way to setup the front end a little higher and angles still look good. How does it ride now with the 285/55?
cbraga
Ride is great still! It did rub on the steps and the lower portion of the rear front fender. With the Amp steps and the 1.5" leveling added to the front seems fine now.
Adam10532
Adam10532
so you ending up going 1.5 suspenstion maxx lower strut spacer with the fabtech 4 inch lift ?
Luggz
