2014 2” Lift suggestions
JTsYUKON
I want to do a 2” lift all around on our 2014 Yukon XL 4wd. The purpose is so I can run a little larger tire. I see several front leveling kits, but I’m not interested in doing just the front. I tow a lot and want to keep some rake. What do you suggest?
olyelr
Elk Rapids, MI
I suggest posting this in the correct section (this is the 2021+ section).
Also, maybe just a leveling kit in the front and a coil spacer out back.
mb1500
As mentioned above the 2” lower strut spacer is cheap and easy up front. Rear coil spacer in rear.
Busynesa
