2011 Tahoe LTZ 285/55/20
Sdesirae
I have a stock 2011 Tahoe LTZ rwd that’s all stock with stock 20s. I’m trying to see if I can fit 285/55/20 BFG K02s without leveling it and how much, if any rubbing their will be or if I need to do any trimming. I have the leveling kit that mounts on bottom strut but I want tog get tires mounted first if possible.
Dantheman1540
Sugar Loaf Mountain
I think you will have no problem, I run a 285/50/20 which is the same width and only an inch taller and I have no rub. I'm also lowered 3/4 inches.
As long as you are using stock wheels, I don't believe that you will have a problem. I'm running 305/50x20 tires on stock wheels, and while the clearance is small in some areas, there is no rubbing.
Smokin Denali
