Bought a 2009 Tahoe PPV and I'm having a no start no crank issue and could use a bit of help.
I was told it started and ran when I bought a few states away but by the time it got here it's not starting.
Put the key in the ignition and turn the key nothing happens, so I break out the ole test light and test the starter it has power but the starter solenoid wire is dead (while key is in the start position). Then I move to the fuses crank and starter fuses all good even the strtr rely under the hood gets power. When I try starting the it the check engine light comes on then about 3 seconds later all the dash light s and odometer and PND321 light up. I changed the ignition switch and replaced both batteries. Any ideas ? Im sure someone some where has had this issue
Thanks guys
Chris
Thanks guys
Chris
