Stage2Tahoe
- Joined
- Nov 7, 2022
- Posts
- 40
- Reaction score
- 16
Just bought an 08 Tahoe 90k on the odometer. It has the flex fuel 5.3, 4L60e, 2wd, and has the LS trim package. I have had problems with the Charging System since I got it home. I took the Alternator and Battery to have them tested and they both passed so I reinstalled them. The Service Charging System came back. I went over the connections again and found the battery terminals were still a little loose. I fixed that problem and it was ok for a couple of days. I was then on the interstate and had to accelerate hard and it kicked the SCS again. It corrected itself then did it again about 15 minutes later (Every time the SCS popped up the voltage gauge dropped to around 12 volts). I did some research and found that a passing test on the Alternator doesn't mean it is working properly so I replaced it. Everything has been fine putting around town until this morning when I drove to work. I was on the interstate running 70. I eased on the gas and as I eased off of the pedal the voltage gauge dropped just below the 14 staying there for another 10 minutes not returning to where its suppose to be (In my opinion)
Is there something I am missing in the system that I need to check? I don't know much about the 08 system, but I know how the charging system is suppose to work. Something doesn't seem right. Any help would be greatfully appreciated.
