Our 2008 Denali is experiencing what I believe to be torque converter trouble. Most of the time I notice it when cruising in the 35-40mph range at low rpm (1300 or so rpm) – when you encounter a slight incline it will shudder so bad that it feels like you are driving over rumble strips. As soon as you increase throttle and/or it down shifts - it immediately goes away. I also can sometimes get it to do it at freeway speeds if the conditions are right. (slight incline, not enough to downshift, and light throttle. I did add some lubegard which seemed to help for a couple weeks but didn’t last. It also seems to do it more often when the summer temps are highest with the ac on. The truck just rolled 100k. The fluid is clean and bright red (serviced at 80k) The trans never hunts for a gear. Never slips and otherwise acts totally fine. I’m hoping there is a simpler fix than a full rebuild. I know on the 4L60’s they sell an upgraded tcc valve kit. I have not found anything similar for my 6l80e. Any thoughts on where to start??
