130k miles require valve ajustment?
Racing4funn
The vehicle is new to me and Im unclear on how the motor should sound but if I was standing next to any vehicle making an audible sewing machine sound Id think to myself there was something wrong with that motor. its too noticable. Trying to understand I removed the oil filter and cut it open. No shavings found.. looked great. So my only thought is a needed valve adjustment but some vehicles arent setup that way..
I did read a lengthy thread here about an acceleration ping/flutter but what Im noticing is at idle.
What year is your rig? You're posting in the 2015 + section but at 130k I'm thinking it's an older model. Also we need to know what motor you have. Sounds like lifter tick.
R
Racing4funn
Its a 2015... are the lifters adjustable or they have to be replaced?
Shaw520
They are adjustable,.... but plenty of ppl go over 130k without adjusting,...unless your rig has lived a tough life....any way to post a video with sound ?
Kpwweb
Could also be injectors. The direct injection fuel injectors make a minor audible ticking sound when standing outside the truck. A slight tick is normal. Especially if the black plastic valve cover covers have been removed. If it is loud, like bolts in coffee can loud, it is not normal.
R
Racing4funn
No way bolts in coffee cans loud. It would take gearhead standing next to it to detect it's strange sound. quite obvious with the hood up. I will try to capture it on video.
Anyone got a link to a how to on the valve adjustment? If I knew what it needed to be the I would pull one cover and start checking. if nothing found I wpuld likly not check the other side. At lest rule that out
I thought the 2015's have hydraulic roller lifters like the earlier years and aren't adjustable? I know my 02 isn't adjustable.
RanchoTexas
