Abuilyas
- Joined
- May 10, 2017
- Posts
- 6
- Reaction score
- 0
Hello all,
Last month I replaced the front upper control arm left and right, sway bar links, both hub bearings, outer tie rods, rebuild the rack and pinion, driver side engine mount, new michelin tyres with alignments (tyres and road alignment) and finally the rear left airride suspension. Sound good? Felt good at the time, however after everything done just before the rear suspension and the engine mount I’ve got traction control light on with traction and stability control service message i did not think it would effect the driving and honestly I thought the steering position sensor is out and since they don’t have it anymore anywhere, just to note when I start the car no error come except when I turn the wheel right all the way or drive a little bet but no message pop up when I turn it left of course it comes on eventually as am driving little more, but couple of days ago I found out that if some how I drove it for short distance and turning only left it become very harsh and the left side bounce in the same time the traction triangle light start flashing rapidly, I don’t have access for any gm code reader and I would appreciate any help or ideas what it could be or where to start
Cruise control work so that check for the brake switch.
check out a video I made for my car when it does that
