Brake problems
Jacob808
Need some help,
I own a 05 tahoe 2wd. I'm having a problem with my front passenger brake locking up.
I've changed the caliper, rotor, hub assembly with sensor and rubber brake line, hydro booster was changed prior to me buying. It's start to lock up after driving for 15/20 min.
nonickatall
Germany
When did you change last time your break fluid?
Your symptoms are as well typical for brake fluid which contains too much water. When you break the break fluid gets hot, turns into Steam and close your caliper.
J
Jacob808
Haven't changed, bleed the brakes at rear till the color was clean. Was very dirty when I did it. Brake fluid looks very clean.
nonickatall
Germany
I dont understand, you only bleed the brakes in the rear and it was dirty, but looks clean?
J
Jacob808
I dont understand, you only bleed the brakes in the rear and it was dirty, but looks clean?when it first locked up I bleed it from the rear. The fluid that came out was dark. I bleed the m
When it first locked up I bleed it from the rear and it was dirty. Bleed the rear till color was clean.
nonickatall
Germany
But when you bleed, you need to bleed all four calippers. So you need to bleed from the rear and the front..
So that means, if you don't bleed the calipers in the front, you will have there old brake fluid and then it's clear why your calipper at your front wheel close while driving..
J
Jacob808
I bleed the rear passager and front passenger. I'll try all 4 and sees what happens
jonjonramblin
