4hi works 4lo just blinks
04xl
Just bought a 2001 suburban z71 with 4 inch lift and 35s and the 4lo won't engage. I can press 4hi and it blinks and then engages but when i click 4lo it just blinks for a minute and goes back, Changed all fluids transfer case, front diff etc and still doing it.. any thought thanks
hcsaturnguy
In my 03 yukon, you have to shift the transmission into neutral before pressing 4lo. If you don't, you get the blinking for a minute and then it switches back.
Mr. 960
have you tried the above post??? It also helps to me rolling about 2 miles an hour.
Cattivo
The Concrete Jungle
Mine does the same, I've tried shifting to neutral and rolling down a hill at no more than 2-3 mph...just blinks :mad:
jerryjoe28
That Guy
cabot AR
when my actuator went out that is exactly what it did. new actuator..... problem solved
BWASTEEZE
