Joew311
TX
I believe he has corrected the yellow paint problem
I did. Ended up getting paint from automotivetouchup.com and it matched the white perfectly.
13yukon
Sylvania ZEVO is the stock taillights. Brake, Turn Reverse and Marker.
Very pleased
CrashTestDummy
Pearland, Texas
Not today, but Saturday, we gave the Tahoe a bath, and replaced the horn pad with a MUCH better example I got from another forum member. Thanks, BillBlatt18!
rebl68
SE Michigan
picked up a new to me 2011 Denali XL on Saturday - 64k on the clock. only missing options are power running boards which I didnt want and the integral trailer brake controller (nothing I tow has trailer brakes....)
since its certified pre-owned, i'm making a list of what needs to be fixed at the dealer.
so far:
  • driver side window/lock switches keep coming undone from the door panel - pretty sure a clip is broken.
  • rear shocks leak down fairly quickly, maybe 30 min.
  • 2 wheels have chrome peeling pretty bad in spots - worth trying for new ones, otherwise its time for some 22's.
  • there's a bit of rust inside the tailgate, on the folded seam. the paint is bubbling a bit but should probably get some attention.
  • anyone have issues with the USB? mine connects to an iphone6 but only looks for a music folder, am I not able to play pandora or anything like this through it? Need to do some more homework here....
I've also convinced the wife (for the 3rd time/vehicle) that it'll need a tune to rid itself of AFM...
Irish83
Alexandria, Va
I replaced the factory fog lamps on my z71 burb with the retrofit source's Chevrolet morimoto xb led fogs (square). They were a simple replacement for the factory ones. Just take the old mounting clips off the lights and put them on the retrofit lamps plug in and you're good to go. I got tired of the hid bulbs burning out and this last time the passenger one came out and melted the housing.
https://www.theretrofitsource.com/c...verado-morimoto-xb-led-fogs.html#.VrT5itHSnIU
Bacovish
Been a little busy so how about what I did this week. Just picked up 2009 extra clean. It had cloth so I had them wrapped with Katzskin leather.
kctyler
Kansas City
Started to wrap the woodgrain...I stopped. Anyone done this with gloss blk. I think the flat blk looks kinda funny.
Sent from my LG-H811 using Tapatalk
montanaboy65
