Denali Gauge Cluster Transferred to Base Model
Justinj360
Justinj360
Well looks like it's a no go. It was hauled away before I could get to it. I can still find a gauge online and install it right?
BillBlatt18
Latham, NY
I plan on just getting a gauge face, needle and stepper motor for mine. Cheaper and I'd rather not have to go to the dealer
about20ninj45
Are there any good write ups for this?
First put on parking break, then shit gear all the way to first, then remove trim cover. There are 4 12mm screws holding in the cluster in all 4 corners. Remove those and cluster will come out. There is also three plugs to remove from the back of the cluster before it will come out
Justinj360
Justinj360
Thanks but I meant just the one trans temp gauge. Like retrofitting it into my current one
mattt
I don't know about about20ninj45's cluster but the one in my 2004 Tahoe and 2001 Suburban was held in place with 4 screws with a 7mm head. Both of my vehicles also had only 1 plug on the top/back of the cluster. The cluster comes out of the vehicle fairly easily, 10 minutes max.
A good write up for adding trans temp gauge is here...
http://z71tahoe-suburban.com/iboard/index.php?showtopic=19909
Justinj360
Justinj360
That is perfect, thank you.
about20ninj45
Hey man 12 mm, 7mm it all looks the same when your going off of bad memory lol n its 1 plug as he stated
BillBlatt18
Latham, NY
Just picked up a 2500 cluster for my 02 suburban. I'll post up when I do the swap
Smokin Denali
