Best lowering kit?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
He has a denali so spindless keep autoride
992dr
N.C.
Gatcha, sorry wasn't paying attention.
What about for non auto ride? Are they a good option?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Yes but will need camber kit just it's listed on my store section. And 5305 coils rear will need free travel mod
992dr
N.C.
Would I need a camber kit with the spindles?
Those coils are only a 4" drop, correct?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
not with spindles but with 4 inch rear drop and spinldes only the 5305 will sit lower in rear than front but the kit comes with a 1 inch spacer will be ok. The drop struts will do 2.5 drop so works out perfect with rear 4 inch springs.
992dr
N.C.
I have 2" drop coils now. That's why I was suggesting the 6" drop coils.
That should work with either strut or spindle, right?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you use drop struts with 2 inch drop springs keep it at 0 drop on the drop struts then the new belltech spindles and camber kit.
2 inch spring/2 inch spindle will need camber kit
cambelsoop1
Wrong. I've been installing and lowering the 07 up autoride since late 06 and springs is not the way to go in front for autoride.
If you want to go all out here I'd the kit
http://www.tbssowners.com/store/index.php?act=viewProd&productId=180
Front spindkes won't change shock stroke so all stays the same
Rear extendeders are used so shock position stats same
Rear comes with autoride links
The 5305 rear cois are best riding and made for autoride where as Eibach isn't
Now the endlinks are fot fixing rear swaybar angle after lowering which helps with handling and the swaybars get rid of a lot of sway
Google tahoe free travel mod this will give you 3 inches more travel and bumpstops I include in set up above bolt in to existing holes already on top of axle.
Anymore questions just ask and I don't just read out of a catalog...... I actually install these kits so can dial 8n what you want
NORCAL SS ...IS This kit is good for a 07 ltz suburban and from what I c everything I need is in this kit. Correct or will there be something else? Can I r u. This kit with 24" without rubbing in the front
Sent from my SM-N910V using Tapatalk
cambelsoop1
Also do u have a kit that goes lower? Can I go lower without chasis work or cutting out something
ColonelAngus918
