Best lowering kit?
black09Denali
im looking to lower my Yukon 2/3. I'm trying to get an idea of who makes the best lowering kit.
fiatdale
Houstons Best
Houston
no - no Eibach kit. It does not lower a full 3" (I have full experience with it). NorcalSS - and he will say Beltech.
1clean08denali
^^^^^^^ this, hit up tony aka norcal ss and get the belltech 2-3,4 drop it's a spindle in the front ( best way to go) amd a coil and spacer in the rear. Kit comes with shock extenders also and I recommend the end link and free ride kit also adds an additional 3" of travel.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Hello, black09Denali. Check Eibach lowering kit. It gains you up to 3" body drop and offers the best quality: http://www.carid.com/2009-gmc-yukon-denali-suspension-systems/eibach-pro-lowering-kit-43151009.html
Wrong. I've been installing and lowering the 07 up autoride since late 06 and springs is not the way to go in front for autoride.
If you want to go all out here I'd the kit
http://www.tbssowners.com/store/index.php?act=viewProd&productId=180
Front spindkes won't change shock stroke so all stays the same
Rear extendeders are used so shock position stats same
Rear comes with autoride links
The 5305 rear cois are best riding and made for autoride where as Eibach isn't
Now the endlinks are fot fixing rear swaybar angle after lowering which helps with handling and the swaybars get rid of a lot of sway
Google tahoe free travel mod this will give you 3 inches more travel and bumpstops I include in set up above bolt in to existing holes already on top of axle.
Anymore questions just ask and I don't just read out of a catalog...... I actually install these kits so can dial 8n what you want
unoigo
Detroit
Deephaven
I've got the kit Norcal linked above. Can't say enough good about it. Rides great and gets it to the right height.
Bruizza
Yep get the kit Norcal is offering up. It is what most of us have used.
kwb0748
Use the djm stuff from tony. Do it right the first time.. I learned the hard way.
ahmedsz
