strokinpower
yea the headlight and grille bolts are 10's and the 4 fender liner bolts are 7's. They are under the bolt because I had to take them back off and fix it when I was doing it lol
---------- Post added at 05:28 PM ---------- Previous post was at 05:25 PM ----------
Looks like you may be on top of the side bolt not underneath. Pull back the fender liner and check.
You are talking about the bottom headlight bolt right?
strokinpower
Is there an off the shelf tuner like a bully dog or super chip that will disable afm and remove some torque management?
YuCanada
Nunavut, Canada
New wheels today;
Administrator
Looking good, David
08grey
Yes the side lower one. Then check if the tab on the inside lower opposite side is in the holder. It's a pop in pop out holder.
strokinpower
yes the headlights are in how they are supposed to be there is just a gap under them because they are actually a little shorter than the oem lights.
dutchinfl
