Couple questions about a supercharger set up
Yukon04
I'm picking up my magnacharger kit this weekend, before I install it just wanted to get a few things clear like, wires, plugs, plug gaps, lower temp Tstat? Anything else I can do to make the kit more efficient.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Injectors, fueling components, plugs. Dont need a lower tstat.
Sent from a jelly bean.
Travieso
Boooooooost !
Los Skandeles, CA
when i installed my supercharger this is what i did
1. NGK TR6ix plugs Part# 3689
2. New 90 Degree Spark Plug Wires from supercharged connection
3. HD Tensioner From Magnuson
4. pin the crank Kit from Magnuson
5. Water Wetter for the Inter-cooler (Heat exchanger)
6. Low-Temp 160° Thermostat http://www.jegs.com/i/SLP/847/100228/10002/-1
Hopefully this works for you
Y
Yukon04
Does the heat exchanger have its own pump and resivoir? I have not picked it up yet so I have no clue pretty sure the injectors are included too.
Travieso
Boooooooost !
Los Skandeles, CA
my kit did come with pump and reservoir, i had to purchase Bigger injectors. my stock injectors weren't cutting it
Y
Yukon04
What size injectors did you go with? Also just to be safe I'm going to add a different fuel pump as well. I plan for 10psi and I have a magnacharger can't tell if its the 112 or 122
jtidd
