1998 Tahoe 5.7 Fuel Economy
SunlitComet
OBS Jedi-Do Good
unknown at this time.
follow the metal fuel lines from the spider backwards. about half way back to to engine rear on the left side of spider. will be a schrader valve with a black cap on it. looking for key on engine off after prime, engine running and large throttle crack.
99TanHoe
Louisiana
Ok, I'll see what I can do this weekend.
SunlitComet
OBS Jedi-Do Good
no this is where attach the pressure testing gauge however, if you wanted to add a constantly monitored sensor and gauge on obs it is the way to go.
SunlitComet
OBS Jedi-Do Good
not yet you just screw on a sensor on but typically the fuel pressure is drained off the valve core is removed and an adapter it use to allow a common 1/8" npt sensor typical of electric gauges.
---------- Post added at 12:40 PM ---------- Previous post was at 12:38 PM ----------
have not gotten to pillar gauge pods yet. besides i still have a lot of wire provisioning to do thru the bulkhead. at least 22 wires.
gpracer1
Phoenix
I may just have to check mine to for sh|ts and giggles.....and a reference point.
gpracer1
Phoenix
report the results here gp.
Ign on eng off 60 psi then settles to 55.
Idle 51-52 psi.
Blip throttle in neutral up to 61 then back to 52.
Light cruise 50 mph 55 psi.
Any load or over 1/8 throttle right to 60 psi.
WOT 61 psi.
SunlitComet
OBS Jedi-Do Good
thanks. any mileage reading to go with those numbers.
---------- Post added at 07:18 PM ---------- Previous post was at 07:17 PM ----------
Also anybody else with these numbers as well for your vehicles.
GMT 900 nut
