Do a search for ultra gauge on here, I have pics.
BTW there is no way you are going to get anywhere near that mileage with huge tires and a lift. Too much aero drag and turning those big tires robs the hp.
An equally important question for you all is how much timing are you guys at while at cruise/good mileage? I know it depends on the ambient temps, but that is where good gas mileage is made.
So at 65 cruising on the freeway with 91 ambient and 93 intake air temp Im at 34.5-36 degrees timing.
Believe me, I had no illusions of getting the kind of mpg your getting. What I meant about comparing your numbers to my numbers was just the fuel pressure difference between my stock and your modded motor.
Is your ultra gauge returning fuel pressure? My Scangauge has the capability to report fuel pressure but for some reason it isn't able to obtain it. I just assumed our older Hoe's weren't capable of supplying fuel pressure from their computers, which is why I also assumed that you were getting it from some other source.
A while back I had checked out your Ultragauge thread but I didn't notice the fuel pressure, I'll have to take another look.
