- Joined
- Jun 9, 2009
- Posts
- 8,744
- Reaction score
- 605
the trucks sit uneven from factory right rear sits higher what I would do is drive it around. The problem people see is after you lower it you can see it much more than before.
Also check the links i never have issues on these trucks and i even used the same kit on my escalade and turned out great but is till have the dam gm lean right rear sits 1/2 inch higher then left rear which is normal
---------- Post added at 11:02 PM ---------- Previous post was at 10:55 PM ----------
you need to drive the truck abotu 500 miles for everything to fully settle. Just wait before you do something thats not really needed.
Like ive told many customers here drive it and thing check it in 500 miles. If needed i put the spacer on the drivers side to get rid of the gm lean that inturn will also lift the drivers side front and get it much more even
