Power seat won't move forward or back
thirsty1258
Hey guys I gave a 2007 suburban and my wife hoppedin it she is 5'0 I'm 5'10. She couldn't get the seat to go forward so she can't reach the pedals. I tried moving the power seats and it reclined and does everything except forward and backward. It sounds like the motor is going I gear a click but nothing. Any help would be great !
sent from my thunderbolt
NASTY GM
Nor Cal
Are you trying it with the truck motor on? The factory battery is weak.
T
thirsty1258
Yeah both ways. Using the same toggle I can raise the height and lower but not go forward or backward
Sheriff
Well, based upon your user name.....
make sure there isn't an empty beer can jammed up under it anywhere.
T
thirsty1258
Ha ha I actually hate drinks but ill take a look maybe a toy or something. It's driving me crazy. But I guess I could bring the pedals up for my wife.
ChevyFreak
New York
Check to make sure none of the cables/plugs came unplugged, or nothing is loose. Also check for any objects that may be jammed under the seat.
GM Customer Service
Michigan
I would check the wires and cables to make sure that there is nothing loose. Also, check to make sure that there is nothing stuck in the track under/behind the plastic. Good luck!
Breanne
Chevrolet Customer Service
T
thirsty1258
Yup everything checked nothin stuck. Do dealers charge to look at it? 81k miles
ChevyFreak
New York
It depends on your dealer, but in most cases - yes they will. Then again, it doesn't hurt to ask if they can just take a quick look. Just know that it may be a bigger problem and will require parts in order to fix. Good Luck!!
T
thirsty1258
Thx for the help guys. Anyone know exactly where the power pedal switch is. I found it and never used it but now I need it and can't remember where. No manual either.
Instigator01
