Blown Bose speaker
neloms
NorCal
I've got the Bose stock system in my 2005 rig and the front driver door speaker is blown. Is this an easy swap or am I going to have to cut out the speaker, splice wires and use self tapping screws to install a new one? I'd change both front speakers at the same time...
Timmy
Brunswick, GA
you should either replace all the speakers or go back with bose. it'll prevent a lot of headaches...
JKmotorsports
Austin, TX
If you do replace them with aftermarkets, you'll have to mount them with self-tappers. The "true" speaker size is 6 3/4", but any 6 1/2" will do. Some companies make the oversized GM 6 3/4" sizes though. For the wiring, you can buy speaker harness adapters that will plug into the stock speaker harness. You can get these at your local stereo shop or Best Buy.
One more thing, the Bose speakers are two ohm, whereas most aftermarkets are 4ohm, so you may notice a slight difference in output.
JKmotorsports
Austin, TX
JKmotorsports
Austin, TX
Yea, that's kinda weird. The only thing I can think of is that he may have been screwing into a harness behind the panel when he was mounting his aftermarkets.
JRSB16
