Can i Level Out (lift) the Front of my 03 Tahoe
bradmps
I think the front is a little bit lower than the back on all models and i would like the even look better
Is there a leveling kit to get them even for an 03 LT?
swtz71
Mass
you can either turn up your stock keys or buy lift keys, ford keys seem to be the most popular.
bradmps
bradmps
Sorry im really new lol but what does that mean
swtz71
Mass
you want to raise the front right?
if I read this right you should try to turn the torsion bar key bolt which is located under the truck about half way down there are 2 one on each side.
What I would do is do a search on here for leveling the front there are some great right ups on this, with pictures..
bradmps
bradmps
yes thats correct.
and are they right near the wheels?
Also do you have you z71 roof rack?
Thanks
swtz71
Mass
not near the rear of the truck more toward the middle to front.
If I remember correctly they're 19mm bolts. take measurements before you turn them up, then an alignment check is necessary.
Yes I have all the stock stuff I took off..
bradmps
bradmps
Ok
WHat all did you take off?
And would the roof rack fit my LT 03 tahoe?
polobuds
East Bay, CA
Ok
no worries man. I was like you, but after spending enough time on here, and getting plenty advice from members on here, you'll learn a lot. Just keep an eye out on threads that talk about lifts/keys. But I found a really good 3-part video that goes through in a little more details about the keys and how to replace them with aftermarket ones. If you plan to do it yourself, you will definitely need a torsion bar removal tool.
Write up by DaRosa is really good and should help too, but if you're more of a visual guy like myself, these videos should help
Part 1 (you could probably skip this part - removing of tires)
http://www.youtube.com/watch?v=hV8R6HvZv4M
Part 2
http://www.youtube.com/watch?v=qrHKw28aAts
Part 3
http://www.youtube.com/watch?v=aZnjz0V2fAw
Good luck!
Off Road Pedia
