anyone running 20x10 295 on the rear of obs 2dr 2wd Tahoe?
JB11
Firts post here and need some advice :Handshake:
I bought a 99 Tahoe 2dr 2wd and Im lowering it this weekend 2/4. I want to run a 295/45/20 tire on 20x10 18mm offset wheel on the rear (20x8.5 front).
Before I jump off the deepend I would like to know if this has been tried and if its doable.
Its gonna be close to the leafs, but Im not sure about the fenderwell clearance inside/outside lip.
Heres a couple mock up pics.
Da90
Tulsa, OK
When I was running 20s with a 2/4 drop. I had 275/45/20s did not have any issues but she did look a little narrow from the back side.:****:
lets see some pics when done!!!!
AtomicHoe094
Atomichoe094
cleveland, OH
your truck looks good man. if you really would have too, you could run a spacer in the back to make em stick out a tad to clear...
JB11
JB11
do you remember what the offset or backspacing was?....these are 18mm and 6.29 backspacing.
The front spacing is approx the same for the 8.5's and 10" wide I bought so if this works it should be pretty cool. But if it doesnt work Im screwed.
Thanks I looked a long time for a nice Tahoe, only has 85,000 miles too.
I bought some 1/4" spacers just in case. I really want this look but I sure would feel better if I knew someone else had successfully done this. Suppose to get tires mounted tomorrow and once the tires are on the wheels theres no returning them :shocked:
chaser0517
I'm 4x4, but the back is all the same. I'm running 275/40r20s and it's pretty tight.
Also running helper bags so it's pretty close to those and the body as well. Rolled the lip on the body and helps. Don't know about 295s, though. Might be extremely close.
JB11
JB11
thanks, whats the offset or backspacing of your wheels
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1 inch of clearance is more than enough. i have 295 45 20 on my dads silverado and have 5/16 from leaf to tire and no problems at all and its lowered 4 inches in rear.
in rear from ground to fenderlip measures 30.25 inches and front 30.5 inches
JB11
JB11
excellent...thats my exact setup and fender dimensions...thanks a million
that truck looks nice, makes me want a cowl hood now
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob ive done tons of those tahoes and burbans and ive fit 315 35 20 in rear no problems. hell i remember back in 95 lowering them and putting 295 50 15 rear and 15x6 front with 165 15s on rallys on my buddys with a 5/7 drop and had a big block check in it with a turbo 400 and a 12 bolt.
John53035
