Engine dies - but why?
Just Fishing
Can't fix stupid
Utah
So was just out messing with it. I pounded, pulled and twisted on pretty much anything under the hood I could get at. It never missed a beat. I pulled one of the PCM connectors off and noticed something I've never seen before. There's some kind of oil in here. To me that's not normal.
oh, you need to smell that stuff to see what it is.
If you don't know, then it's time to start sniffing fluids and compare! :jester:
Just Fishing
Can't fix stupid
Utah
It also makes me wonder if you got some oil in that PCM somehow...
:hmmm2:
Super Moderator
Elev 5,280
As noted before, oil can migrate through an electrical harness from a failed sensor seal.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
So ended up having trouble with it again today after work this morning and was supposed to be going somewhere with it but ended up leaving it sit for the afternoon (this after making a trip into town from work). Started fine when I returned a few hours later. On my drive home the engine very briefly cut out for the first time. But there is a registered code P0335 for the crankshaft position sensor now. Now we might be getting somewhere.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
Apparently though a new sensor requires a relearn process with a scan tool and I don't have one. So don't feel very good right about changing the sensor.
wjburken
Eastern Iowa
Crank Shaft Position Sensor you say? Hmmm……
Now you have something to work with.
Super Moderator
Elev 5,280
A CASE relearn isn't necessarily "required" after changing the sensor, but it's recommended. Not doing it might show random misfires, or not.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
I had seen a couple things where the relearn wasn't required for AC Delco sensors. Is this actually true? I would think not.
SWoolf777
