2015 Tahoe/Grinding/rough noise from front of vehicle
fatmonk8
fatmonk8
Is this noise/sensation impacting drivability or is it just an annoyance?
As of right now it's only annoying. But I don't know if it's the start of something worse. I can slightly feel it through the floor and pedal.
Car seems to work perfectly fine though.
NickTransmissions
Sin City
The transmission bench
Then I wouldnt worry about it, unless it gets worse and if it does get worse, it will be a lot easier to pinpoint.
fatmonk8
fatmonk8
I think my last couple things to check are the transfer case and transmission fluid. They need to be done anyways, and maybe the fluid will tell me something I'm not seeing.
After that I have an appointment at my local mechanic anyways to get the truck realigned and have the steering sensor reset. So if it not fixed by then I will have them look at it.
Hopefully thoes last couple things will help me prevent needing to ride it until ot gets worse.
NickTransmissions
Sin City
Could be transmission but if its a grinding noise and it's coming from the transmission, life expectency is usually measurable in days or hours.
Drop the pan so you can see what's there. If kibbles and bits are on the bottom, you've found the problem.
fatmonk8
fatmonk8
I would actually be surprised if it was the transmission since it shifts and drives smooth. But I had already bought a new filter and gasket as I planned on dropping the pan and replacing the filter a while ago.
Crossing my fingers it's not either the tcase or transmission
NickTransmissions
Sin City
I would actually be surprised if it was the transmission since it shifts and drives smooth. But I had already bout a new filter and gasket as I planned on dropping the pan and replacing the filter a while ago.
Yea I dont think so either as it seems you have been dealing with the problem for a while now and any grinding is almost always gear train and gear train parts usually self destruct bery quickly...post back once you found once you've dropped the pan and inspect it.
fatmonk8
fatmonk8
Will do, thank you for the help!
fatmonk8
fatmonk8
Drain plug for the tcase.
Seems like a lot of metal to me.. no big chunks though.
APalmer15
