I'm a moron, I was picturing percussive maintenance as a way to test for a leak. Like, does a leaky manifold sound differnt when you tap it with a hammer vs. a manifold tight to the block.
I'll just be over here looking for the ID-10T oil.
usually you can hear it on a cold start if it is leaking
RooTBeeRthe1st
Yeah, I realized you took it that way so I wanted to clarify. Lol
Just wanted to say this thread is a godsend to get reminders of when you did repairs on your car. I forgot when I changed my plugs but seen it was in June 2020 around 210k miles. Currently Jan 2023 with 247k miles. I see a slight idle issue and I know its not plugs.
clean the intake and throw some injector cleaner in it for a few tank fulls, usually that will smooth the idle out, plugs should not go bad that fast unless they were fakes. I drive the pisss out of mine and the only change the plugs about every 60 or so and never have any misfire issues. I do clean the intake about every 3 months and randomly throw injector cleaner in it probably about the same every 3 months or so.
if that doesn't work have a injector service done, that usually runs under a $100, usually around $80 but inflation has hit so no telling anymore.
justchecking
Military
SW Ohio
Two Three great things today. First, I fixed my "Battery Voltage Low - Start Vehicle" by just tightening the loose positive battery connection. Second, my insurance company was able to recover the $500 deductible from the uninsured motorist who rear ended me a few months ago and sent me a check today. First, I woke up on the green side. Second, I fixed my "Battery Voltage Low - Start Vehicle" by just tightening the loose positive battery connection. Third, my insurance company was able to recover the $500 deductible from the uninsured motorist who rear ended me a few months ago and sent me a check today.
Two great things today. First, I fixed my "Battery Voltage Low - Start Vehicle" by just tightening the loose positive battery connection. Second, my insurance company was able to recover the $500 deductible from the uninsured motorist who rear ended me a few months ago and sent me a check today.
a check in the mail is always nice, I had a guy clearly run a red light on dash cam and they still initially said I was partly to blame but changed it later and sent me a check as well. completely mind boggling, but whatever
Managed to get it off somehow without breaking any plastic tabs which is unusual for me, appears the screen cover is plastic welded on and they just gave out, luckily the post's are large enough and already hollow inside so I just put some small screws and washers in it seems to be good enough saved $90 for a used seat back which would have been the next choice PXL_20230209_015449314.jpgPXL_20230209_015454090.jpgPXL_20230209_015943837.jpg
Corrale
