Lowered Tahoe
Edwardnavalo
I have a 2003 Tahoe 2wd I just bought , according to previous owner it was lowered on the rear , and Tahoe rolls side to side on freeway really bad , any one have that problem before ?
LordWayback
Swaybar bushings are a known problem but it could be something else especially if it’s really bad I would go to a place like big brand tire and Atleast mine will give a free or cheap inspection you could be in for as little as sway bar bushings or all new rear suspension.
E
Edwardnavalo
Thank you , previous owner told me it was lowered 1 up front and 4 in the rear
As @LordWayback stated above, get it checked out by a local quality repair shop, just to see if there are any suspension-related issues (particularly bushings and links conditions) that exist that can be identified and repaired/replaced.
If everything checks out as OK, consider purchasing a set of Hellwig sway bars for your truck. They are pricey, but they will eliminate any and all body roll.
Many folks on this Forum have lowered their trucks, and they will chime in regarding handling characteristics changes after lowering the truck.
E
Edwardnavalo
Thanks I took it to a shop and was told that my sway bar needs to be parallel to the floor and mine at the moment is towards the floor
2nd part of your problem are those shocks. I had them on for maybe a week or 2 then tossed them in the garbage. They suck. Do you have ZW7 in your rpo codes?
E
Edwardnavalo
Yeah I do have the zw7 , what shocks did you go with ?
E
Edwardnavalo
The part number for these is 344045 , and when I look them up on autozone it gives me a different one . If it has shock extenders can I still use the Oem length shocks ?
I have Bilstein 4600. ZW7 comes with the Nivomat shocks, which are really firm, so the springs are a little soft. You can't use non Nivomat shocks with the Nivomat springs, if you do then you'll be experiencing the exact conditions you're having now. Same thing happened to me until I used lowering springs. It was really scary driving on the highway. It was like someone was pushing it side to side in the back.
pastormat81
