Cruise Control Only Working Intermittently
Billy in Philly
My 2008 Tahoe LTZ cruise control used to occasionally not work, but now it works very little. The on/off button on the steering wheel lights up when I push it, but from there, the cruise control functionality doesn't work and obviously the green "Cruise" light on the dash panel doesn't light up.
Anyone have any insights or experience with this? Looking for a fix as long as it's not too expensive. Thanks!
MWagoner
I have been having the same issue on my 2011 Tahoe. I’ll be curious to see the responses as well.
Eugene Sapiro
Eugene Sapiro
I heard that its could be a problem with a switch under your brake pedal. Cheap to replace that.
It is probably the brake switch since the power light stays on when it works and doesn't work. That would be a clock spring or control module issue.
Don't attempt to repair the switch or clean the connectors, it never works for long. Steer clear of aftermarket parts.
Switch, Stop Lamp 25981009 or D1539J
Same switch and packaging with both GM and ACDelco part numbers.
