Need help 15 Tahoe fan stay on after turning it off.
Javier Hernandez
Got a 2015 Tahoe the electric fans stay on after I cut the truck off. I changed out the thermostat and the temp sensor, but I can’t figure out the problem, now the heater blows cold air and the air blows hot air I’m lost please need help TIA
Masonson
Greensboro, NC
My wife just got home from work and she's having this exact issue for the first time.
2015 Yukon Denali, Coolant temp is pegged at 160, 45 degrees outside, trans temp is not hot either.
Multnomah Falls
Military
Masonson
Greensboro, NC
So I disconnected the battery, let it sit for 20 min.
Reconnected battery and started the truck up, coolant temp came up from 160 and the fan did not come on. Im thinking the coolant temp sensor had a freakout and the electric fans just fail-safe turned on. We'll see.
Javier Hernandez
Javier Hernandez
I did the same thing I disconnected the battery and the temp went up to normal and the fans worked the way they should but it started again and I don’t know what it could be
Masonson
Greensboro, NC
Have you found anything out? I replaced the coolant temp sensor, it worked for a couple months but started again.
sb38646
Same replaced sensor but still the problem persists. Still resetting battery when it occurs
Pawaso
