Removing the driver's seat question?
jdpromo33
Proud Tahoe Owner
Bloomfield, New Jersey
Hey everyone.
I just got my new heated seat pad and new leather seat cushion delivered today.
In order to fit this in nice and proper, I want to remove the driver's seat to install.
How do I remove the driver's seat?
I moved the seat all the forward and back and only see 2 star shaped bolts.nuts on the outside track. cant see anything on the inside track.
Any help would be appreciated.
Thanks
JD
thehoe92
fo sho
The916
2 star shaped bolts in the back and 2 in the front
they are different sized
I don't know what tool to use for them so I found a socket that fit and used a breaker bar
watch out though you are about to find some nasty shit under those seats!! haha
good luck man take some pictures
jdpromo33
jdpromo33
Proud Tahoe Owner
Cool but I only see 1 in the back and 1 in the front both on the same side
Riff Raff
Arlington,Tx
on the inner side there should be some plastic caps that pop off those bolts
front and back inner bolts
cam3439
Look at the four pics below to help you out. If I remember correctly, when I did my seat mod I had to use 15mm (fronts) and 7/16 (rears) sockets. I used my 1/2" drive ratchet and it was sufficient. The other two starred sockets/bolts that hold down the inner rail are covered with trim. The first pic shows the plastic trim that has to be popped off (toward the door), and the fourth picture shows the other inner rear bolt that was hidden under the plastic trim (you can see the tan/neutral trim on the right side of the pic on the carpet).
jdpromo33
jdpromo33
Proud Tahoe Owner
Thanks JP and Joe and great pics. Lot of good help there
Thanks again
JD
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I used E-torx sockets from harbor freight.
I didn't full remove them from the truck though.
I just did it to clean under there.
nooner827
Thanks for the help, guys! 7/16" and 15mm worked perfect for me. The only glitch for me was that for the front seats, the bolt was sticking too far through the nut. Luckily I was able to get enough of a grip with the wrench by seating the socket on the nut and partially engaging the wrench. Not sure if that makes sense to you. Deep sockets would have worked if I had them in those sizes.
SnowBuck
E-torx
I did it too...simple when you have the right tool for the right job.
caprajohn
